PLTV 10? East
  • dick b
    • Jun 2009
    • 2462
    #91
    Originally posted by Peterjones
    I know slightly off topic but does anyone recommend any other decent BISS encrypted channels to likewise I can view with a bit of coding on the box?
    open this with "notepad" all the Biss channels are after the softcam(including now the new pltv one) they dont all work and some are FTA anyway but try M*M ME also on 10E as a starter I havent tried them all but 53East is ok (if your russian)
    • vorlon2257
      • Sep 2011
      • 356
      #92
      The problem is although the info is there from what I can see, most of what you need is on other forum's which means having to sign up to that forum to get the software.
      You will also need a HD PC Satellite card as well as a nvidia Card that supports cuda.
      • Peterjones
        • Dec 2012
        • 34
        #93
        Thank you very much.
        This is probably a really silly question, however when looking for BISS keys on the internet you see all these other encription files. Where on the box would I put these? I'm guessing these dont go in the text file which holds the BISS keys?
        Eg: in that file the Bulsat files etc are listed there, however can I stick them in my constant file where my BISS keys are stored? Also does it matter that the BISS keys listed there are in a different format to those which I currently use? (sorry for the silly questions, however actually enjoying learning more on this site as people will answer questions)
        • digicon
          • 8261
          #94
          The problem with most of the softcam makers is that they dont update the biss keys often enough so what happens is you can get 2-3 different softcams from different teams some will open certain channels and vice versa, This is where people need to do a bit of work record the keys that work in each softcam and then combine them all into your own this way everything that should open will open
          • digicon
            • 8261
            #95
            I dont see the harm in having to sign up to other forums its all part of the learning process as some forums cannot discuss certain topics and some can. This way your broaden your knowledge base.
            • dick b
              • Jun 2009
              • 2462
              #96
              for Biss keys I just use techsat software it is found on another forum its true but its free so not a problem heres a technomate version anyway.
              • saj1985
                • 785
                #97
                for those of you who use minicats bundle,
                his bundle is already updated...
                however i noticed that the key within the minicats bundle is different to the one dick b has posted,
                how many different keys is there available to clear the one channel?
                Originally posted by ramjet
                yes it works 100% ( o ye of little faith )
                as for the biss key, apparently its extracted using brute force from a video recording of the channel itself, using tools called cudabiss and Table RBT FF 200 GB and something called CSA Rainbow Tool, not that I have tried this but the info was posted on the net
                from what i read you,
                need a nvidia graphics card which i have,
                i found the csa rainbow tool no problem,
                but i've been searching for that table for ages with no luck,
                if anyone knows where to find it, please enlighten us...
                Dreambox 800hd se/Dreambox 500s, 90cm Solid Dish, Tm2600 Motor, TM-1 Gold LNB!
                • dick b
                  • Jun 2009
                  • 2462
                  #98
                  Originally posted by den1
                  Have come across the BISS keys for 10e PLTV. which are working in my TM5402 H/D.
                  DEN
                  not haveing a dig but open posting of keys is a no no.as non members can read them.
                  • ramjet
                    • 2995
                    #99
                    the answers vary according to the box , the firmware and files used, which is why most forums have different sections to take care of the different boxes and file formats
                    so there is little point replying to most general posts due to the fact that specifics are required, and your post seems to indicate a linux box which is why there are various linux forums here, as well as on other sites
                    the type of emu used may also be a factor
                    so my advice is to ask specific questions in the appropriate forum
                    • jon48
                      • Apr 2010
                      • 147
                      #100
                      pltv
                      all working here ok
                      • McrRed
                        • Jul 2010
                        • 86
                        #101
                        Originally posted by jon48
                        all working here ok
                        Is that with the *new* key?
                        PL working?
                        • Manic01
                          • 5117
                          #102
                          Yes its open again.
                          • jon48
                            • Apr 2010
                            • 147
                            #103
                            pltv
                            yes with the new key m8 ..
                            • hsbajwa316
                              • Aug 2012
                              • 23
                              #104
                              not working, I manually edited the new key and its not working now (did before) any ideas. tried restarting the Cccam
                              • Manic01
                                • 5117
                                #105
                                Def works mate.
