Starview hd combo help
  • elsunshino
    • Jul 2011
    • 4
    Hi, was wondering if anyone can help, i upgraded my starview combo carling firmware to latest version F531, the problem is now all my cccam lines seem to have been blanked out, i now want to downgrade the carling version as iam getting constant freezing but if i do this my cccam lines will dissapear and i will have to renter the details manually again, as i cant see the lines due to them being being blanked out, i havent made a note of 1 of the ccam lines as i have 3 on there, is there anyway i can unblank the cccam details or transfer the ccam lnfo on to a usb???
  • ramjet
    • 2995
    you may be able to transfer the cccam info to usb but you cannot unblank those lines, it was done deliberately in those firmwares to ****** out the hosts info etc
    a better solution, if you know your cccam info already, is to reprogram it with the spiderbox firmware from the file "I WAS BORED ONE DAY" from the starview section sticky threads, and then use your usb to flash it to march 2012 spiderbox firmware from the mandatory spiderbox patches thread in here
    this will give you better menus, menus you can read in the cccam section, ability to use spiderbox channel lists and softcam, and other extras too like card reading
    you will lose the cable side but thats only fta channels anyway
    • elsunshino
      • Jul 2011
      • 4
      Thank you, i have been thinking about putting the spiderbox firmware on to this box, will give it a try this week
