Hi Friends,
This is a review from me I have had almost all boxes so this is a fair and honest user review/comparison.
In my view the spark is okay but not great, if you are used to E2 or decent boxes then i doubt you will grow to use spark although it is 100% better then openbox etc
It is NOT worth ?100 as the company making the boxes should at LEAST support emus!!, this box will run oscam for CCCAM users and mgcamd also works but ONLY mgcamd 1.33, no 1.35 or 1.38.
Certain builds support cccam but it is not as standard as better supported boxes, ie MOST boxes support at least cccam and mgcamd off the shelf!
The remote look great when your first see it BUT it is cheaply made and once you start using it you will notice the build quality by the horrible cheap clicking sounds, ANOTHER thing to note especially for E2 users is that the colour buttons are located in the wrong place (ie blue button for favorites etc), it is too low. (nothing major but potential buyers should know the pros & cons)
E2 images are simple to install but are all in alpha state at the minute, in saying that the PKT v3 image seems to work great on this box.
1 channel plugin also works fine in e2.
Spark OS works well but most of the online functions do not work in europe.
In short the box is 100% an openbox killer and is a very good alternative to openbox and other similar boxes (100% times better than openbox models), BUT it is not as slick as a vu solo/duo or dreambox dm800.
It is not worth ?100 rrp due to limited support from the manufacturs and VERY limited Emu support and also the low build quality. If you can get the box for ?70/80 then it is worth it over openbox etc, but seeing as a dm800hd is now ?100 (from china), i would stick with that as it is tried and tested.
PS: blade is good box but way overpriced at ?149, this box is similar to the blade and much cheaper althought the blade build is much better and the support for blade is also better then amiko alien. But dm800hd is still the safest bet!
Any questions please feel free to ask.
