SATlink WS-6909
  • albaniansniper
    • 132
    SATlink WS-6909
    Just purchased one SATlink WS-6909 from ... will tell you later up in request (cheapest that I can fine online) but would like to know if anyone has had one and how good or bad it is?
    If it is very bad then I will be more then happy to take the pain.
    * Dreambox 800 HD se
    * Kryptview a780
    * Triax TD110 1.1m Solid Dish
    * Birds: Eutelsat 16e/ Astra 19.2e/Astra 28e
  • mdt
    • 3034
    worth the money for the occasional install/keeping your own system bang on but has problems in bright sunlight. regards mdt
    • albaniansniper
      • 132
      Thank you for that 'mdt' I feel much better now.
      Regarding 'problems in bright sunlight'? Well,I just have to apply some protective Sun Cream and job done.
      * Kryptview a780
      • dick b
        • Jun 2009
        • 2462
        I made this sun visor up for a ws-6906,because as MDT says you cant see the screen in sunlight no laughing at it as it works a treat,I"v had the meter over a year now and its great for personal installs.
        • albaniansniper
          • 132
          Many thanks for that. I'll report back when I get it to work.
          Kind regards.
          * Kryptview a780
          • albaniansniper
            • 132
            Finally item arrived from China! Looking good so far but one thing is missing? The_ USB CABLE?
            Does anyone know what type of usb cable do I need to connect this satfinder with my pc?
            Many thanks.
            * Kryptview a780
            • vorlon2257
              • Sep 2011
              • 356
              I think it might be this 1.....
              New 70cm USB 2.0 Male A to B Mini 5 Pin Cable Lead XC03 | eBay
              • dick b
                • Jun 2009
                • 2462
                Many thanks.
                I did get one with my 6906 its usb to rs232 but to be honest I"v never used it as you can update TPs/add channels etc manually without any bother.
                • albaniansniper
                  • 132
                  Apparently I have that cable somewhere but my desktop pc only have one output connection which is for the monitor.
                  Also instead of a usb to rs232 can a USB Male to A Male Cable do the same job?
                  * Kryptview a780
                  • dick b
                    • Jun 2009
                    • 2462
                    I dont know but dont think so others will know more than me.older desk top pcs usually have an rs232 port.which is not the same a monitor connector.
                    • dick b
                      • Jun 2009
                      • 2462
                      this is what you are after mate
