ok i see on the kingofsat new frequency/sid for 14 sbo channels...but with over 35 sbo channels on channel list how do you configure which which new frequency to what sbo sky number needs to be changed? http://en.kingofsat.net/freqs.php?&p...re=no&aff=list
sbo numbers
Hi m8,
Depends on your box,you can either go through setup manual scan transponder in menu on stb or use dreamedit to do it... -
Ok it aint got one of them,but think it might be trial & error and having ago of making your own...Comment
Check them on a sky box, but you will never really get them right as not all channels broadcast all the time. Pinch my list and use the sbo from that. Anytime I've tried to watch an sbo those numbers have been pretty good.ok i see on the kingofsat new frequency/sid for 14 sbo channels...but with over 35 sbo channels on channel list how do you configure which which new frequency to what sbo sky number needs to be changed? http://en.kingofsat.net/freqs.php?&p...re=no&aff=list
Sent from my GT-I9300 using Tapatalk 2Comment
You have a great list highlander, but me and the family are used to the sky numbers.....if i did a blind scan and then added the numbered list would that automatically change the list frequencys?Comment
No but if you notice on my list even though the sbo channels are not on the sky numbers they have the sky channel number in the name of the channel. That will give you a good head start in trying to decipher what ones have changed. Just scan the individual transponders that the sbo channels are on instead of doing a blind scan. You can then upload your channel list from box to usb stick and edit it on pc with Clarke tech
Sent from my GT-I9300 using Tapatalk 2Last edited by happy_highlander; 16 December, 2012, 01:16.Comment
managed to get the frequencys changed over
Have noticed that on lyngsat for some channels old frequencys are listed yet it says they have been updated.
for example check out star plus hd....lyngsat list it as 11261 h 27500 Star Plus UK - LyngSatComment
Yes mate lyngsat can be slower. Best way to get new frequencies is to use a Linux box to scan a channel list for 28.2 then check any changes that haven't been picked up by kos. It has made my life a lot easier.
