been watching it here all afternoon without a hitch in the north west on a 1.25m Gibertini with black pro and feedhorn, Signal is slightly down as according to my receivers SNR i usually pull in around 97% on a good day but for the last 2-3 days i have only managed around 85%.
If i recall this happened around 2-3 weeks ago it dropped transmission power of around 3db not sure if this was on purpose but i got reports of some people losing it on 1m dishes with varying makes of LNB
depends on what box
basically if you have usals set up in the first place just change the latitude a bit for example 1.9w to 1.8w and see if your signal improves
read this
