Help with Nagravision 2
  • jmauver
    • Jan 2013
    • 6
    Hello community,
    I am new here and I would like to know if anyone could give some advice on the following:
    Many years ago I used to watch a channel on hispasat using my Humax 5100 (two CI slots) together with a Matrix Revolutions CAM. After moving home, I was unable to use a dish in my flat. So, for many years, I forgot about this matter. Now, I have access to Hotbird and my old Humax found that channel I used to watch. However, it is now in Nagravision 2, instead of 1. I understand that my MR CAM can't be used for Nagra 2 and perhaps my Humax is a bit old to handle that too.
    So I see there is a STB called DM 500S, which costs around ?40.00. Despite the fact it does not have a CAM slot, I understand that some people use it for Nagravision 2. Can anyone confirm that for me please ? Or perhaps a better solution for Nagra 2 ?
    Thank you for reading and any feedback left.
    Jmauver
  • mdt
    • 3034
    Originally posted by jmauver
    Hello community,
    Jmauver
    which channel are you refering to? regards mdt
    • jmauver
      • Jan 2013
      • 6
      Hi mdt,
      It is called TV Globo International (ID C102 13? E Hot Bird).
      Thanks !
      • mdt
        • 3034
        Hi mdt,
        Thanks !
        its open via softcam on most stb,s and hasnt changed key for 2 years.. ivejust done some digging and it seems there is no patch for the 5100 but is for 52/3/400 series albeit older patches with updated softcam. the dm500s will do what you want via certain emulators, c**am,mgcamd ect. regards mdt
        • jmauver
          • Jan 2013
          • 6
          Thank you mdt. I think I will go for DM500s, as it has linux installed and I used to support that operating system. How things have changed since 2001, the last time I used my Humax, bought in Germany when I was living over there. Again, thanks for your time and precise response.
          Regards,
          Jmauver
          • jmauver
            • Jan 2013
            • 6
            Hi mdt,
            My DM500 arrived yesterday. Still trying to figure out how to use it with cccam. Can I ask you again a question ? Is it mandatory to connect cccam to server in order to decrypt a channel or cccam can use a local file (softcam) with hexa codes ? I ask that because I see some people making codes available to watch some channels, including the one I am looking for.
            Thanks a lot !
              Yes you can use a softcam file with CCcam as the reader without internet connection to the DM500s
              • jmauver
                • Jan 2013
                • 6
                Thank you digicon. Is there a guide how to enable softcam on CCcam ?
                • mdt
                  • 3034
                  you need to ftp the softcam.key file into var/keys and then dependant on image used just press usually blue but could be green/yellow/red untill you get the softcam menu where it should say 2 softcams installed. common interface and c**am... select c**am and save and restart or ok for the cam to start. regards mdt
                  • jmauver
                    • Jan 2013
                    • 6
                    Thank you again mdt. I will try that today.
