Help required connecting to dvb box
  • Paredes
    • Jan 2012
    HI,
    iam hoping some one can help I have a set top box its only got dvb hd on it i think it some type of dreambox clone, i need to browse to it so i can install a cccam.cfg file but can not do it
    i have tired browsing to its ip adress 192.168.1.88 throgh a web browser but nothing then i down loaded dreambox control centre and selected connect throgh router i get the green line but then i get an error code socket not connected ?? its doing my head in also on the db control centre the ip adress for the computer is diffrent from the ip whn i use cmd propmt ipconfig which i thought was strange any ideas desperate
  • sexysam
    • Oct 2008
    • 209
    Try Filezilla, it does the same thing as DCC
    • andy91
      • 3583
      Go into the menu/setup/network of the box and do a network test.
      If you get a green tick on ip address that's the confirmed ip.
      I like to use flashfxp you can find that in downloads.If you search the forum there's a tutorial on using flashfxp
      Andy.
      • Paredes
        • Jan 2012
        ip
        hey,
        thanks for the replies so far
        i hvae checked this setting in the box and give gives the ip , gate way and subnet mask
        the ip is 192.168.1.88 dhcp assigned but whe i use dreambocx control centre the green line goes to the box then i get an error socket message i dont understand it ...
        i will try a diffrent app to dreambox control maybe
        • andy91
          • 3583
          Best way is to do a network test if you get the green tick thats the ip of the box.
          You could assign your own ip address and have a static ip which i would recommend and disable dhcp.
          If you type the ip address into your browser bar of the laptop and hit enter and you get dreambox web control up then you know its correct.
          Do the test first,
          Andy.
          • kegnkiwi
            • Sep 2009
            • 81
            It sounds to me that you have not set a password yet for the box. To allow files to be send too and from the box the password needs to be set. Click on the telnet button and it may still allow you access to root. In the telnet session type passwd this should then promt you change the password. If it does not work in dcc then use a program called putty.
