is newcs the same as newcamd
  • smirnoff_rules
    • 8603
    had a share from a guy and says it works better on newcard that ccam , l looked all over and couldnt find newcamd so l installed newcs/camm2.14 and it works and seems ok now . are they the same ?
  • mdt
    • 3034
    from what i can gather there different as newcs reads the card and c**am does the other bit whereas newcamd does both... of course i could be wrong as im far from an expert in these matters but im sure others will confirm for you. regards mdt
    • **OVERRIDE**
      • 199
      Basically you been given a N: Line
      newcamd takes less data then CCCam,
      You either add it to CCcam.cfg in CCcam
      N: myfriend.dyndns.com 15000 myname mypass 01 02 03 04 05 06 07 08 09 10 11 12 13 14
      or
      Newcamd.list in Mgcamd
      CWS = myfriend.dyndns.com 15000 myname mypass 01 02 03 04 05 06 07 08 09 10 11 12 13 14
      • smirnoff_rules
        • 8603
        for the life of me l cant find newcamd on any servers the 800 ?
        • **OVERRIDE**
          • 199
          Hi,
          Clients use Mgcamd m8....
          • mdt
            • 3034
            it still exists but most people use mgcamd now to read n-lines... i think theres v5.25 and v6.10,regards mdt
            • smirnoff_rules
              • 8603
              l have that installed but he said use CWS = XXX blar blar blar
              but where to l but his THING ?
              • **OVERRIDE**
                • 199
                Need too install Mgcamd 1.38,then add line in Newcamd.list
                • smirnoff_rules
                  • 8603
                  is that in /var/keys/ if it is l have added but not showing picture ?
                  • **OVERRIDE**
                    • 199
                    Enigma 2 usr/keys
                    • smirnoff_rules
                      • 8603
                      cheers will contact him as see if thats turned on l have it in there , cheers lads
                      • **OVERRIDE**
                        • 199
                        Cheers m8,
                        let us know if your sorted,also there in the keys folder there should be a mg_cfg file which mite need editting...
                        • smirnoff_rules
                          • 8603
                          all working now lads have 2 on there but need away to see them now , l cant use the webbrowser now , wots the best way to see if there on or off , like to see both at one time to see if u get me
                          l could just leave in ccam info and turn that back on and check on web tho , but wondered if theres another way
                          • **OVERRIDE**
                            • 199
                            Tbh only use web browser with CCcam,which all you do is add your lines too cfg file,only way with mgcamd is log file
                            • smirnoff_rules
                              • 8603
                              ok , will just switch cams to check
