starview hd combo to spiderbox
  • punxxxter
    • 184
    hi
    do i use a null cable modem lead to change starview combo to spiderbox
  • ramjet
    • 2995
    Originally posted by punxxxter
    hi
    yes, and the software and loader are in the starview section sticky threads (i was bored one day)
    • punxxxter
      • 184
      cheers mate ill try it later...
      • punxxxter
        • 184
        been a long time since i messed with this box and cant remember how to get the hidden network menu on screen.
        any ideas?
        • tornado
          • Oct 2008
          • 218
          menu network press 1111 and it should show up
          • ramjet
            • 2995
            any ideas?
            8989 was the sv code
            1111 is the spiderbox code
            • punxxxter
              • 184
              thanx to both for replys....
              right, box is flashed do i just put both patches on?
              • punxxxter
                • 184
                also where is the channel list ?
                ive looked in starview downloads....
                • ramjet
                  • 2995
                  after patching to spidey, load the spidey mar 2012 patch from mandatory patches thread
                  then use one of the several spidey lists published on this forum, and the spidey softcam, and also the biss keys too if required
                  • redondo5
                    • 277
                    Wow, i didn't know this was possible.
                    • punxxxter
                      • 184
                      hi again
                      ive found the spidey mar 2012 patch and loaded it on, also put the soft cam file on aswell.
                      all the other files i cant find.
                      now where do i enter my lines?
                      i remember ages ago when it was starview i had to use remote control and manually enter it some where in he network settings....
                      • ramjet
                        • 2995
                        hi again
                        highlight network in accessory and press 1111 and keyedit will appear above it
                        then check the network settings for client
                        all the files are in various threads on this general sat forum
                        biss keys
                        channel lists
                        softcams
                        • punxxxter
                          • 184
                          thanks to every one for the help with this...
                          its up and running but i have a fair few channels missing,
                          also is there any downloads to put the channels in categorys
                          like , Music, Films, and sports...instead of a list?
                          • ramjet
                            • 2995
                            depends which channel list you used , billybits or william1 or one of the others like mine for instance
                            you should have a FAVS list and thats where I store categories like you asked about
                            if you install a channel list, it should contain the favs already, and biss keys too
                            • punxxxter
                              • 184
                              hi again,
                              i have nothing in favs and what are biss keys?
