blade bm7000
  • craggz
    • 115
    blade bm7000
    my box frozz up with lnbf on front off box ,done master reboot ,,... back to star t but locks back up when i go to scan for chans /// help
  • zee24
    • 3342
    have you done a factory reset by switching off the box, holding down the menu button on the front of the box, then switching it back on until the blue screen appears with 4 options 4th should be factory reset.
    • ramjet
      • 2995
      lnbf is low noise block fault, so check your sat cable hasnt shorted, ideally remove the feed , switch on and see if the message is still there or not
      if not, check the cable for short circuits or damp
      • craggz
        • 115
        took sat cable out loose conection on sat cable sorted thanks
