New Box... Any Suggestions please?
  • zeroms
    • 5
    Hi Fella's
    I've had a Spiderbox 900HD and an Openbox S9 in the past, my Openbox has just packed up and the Spider is at the inlaws, I'm in need of a new box.
    I'd like something that has a decent EPG, and the possibility to stream the TV in high quality full screen to my laptop so I can watch the same channel in the bedroom
    Any suggestions much appreciate please?
  • ramjet
    • 2995
    Originally posted by zeroms
    Hi Fella's
    check the usual suspects of a vu duo or vu solo2 or dreambox or similar (all linux based)
    • zeroms
      • 5
      Thanks Ramjet, I looked at your suggestions and have just got myself a VU+ Solo2
      I like the airplay idea very much!
      • zeroms
        • 5
        Out of interest, I currently only have a standard Sly dish and 1LNB, what would I be best getting to replace this, I only use the box for UK stuff so do not require anything motorised, but I need 2 lnbs right?
        • Shady
          Shite Link King
          • Dec 2010
          • 6404
          no.. need 1 dual lnb for a twin tuner box.. or a standard lnb for a single tuner
          • ramjet
            • 2995
            if its a standard sly dish you wont find any cheaper lnb than a quad sly lnb on flea bay
            so a quad lnb and a shotgun cable or 2 separate cables are best, one for each tuner
            a twin lnb will cost more money and give nothing extra, whereas a quad is cheaper and also allows for further expansion in the future
            sly do not fit or sell twin lnb,s, so buying a twin would cause fitting issues too
            so my advice is buy a sly quad lnb with legacy adapter and fit it yourself, and double up on the cable, or replace it with a shotgun cable same as sly use for sly plus HD
            also, if using the spiderbox you still need that 3rd output from that quad lnb
