i need to set up satallite sytem in europe
  • zetasprite1
    • 33
    Hi to all,
    i would like to set up a satellite system while i park up while traveling abroad in europe ie france, spain ,etc what hardware should i use. can i take my uk hardware and set that up .is it more complex than that, i came across a polish driver who had his dish mounted to a pole and breeze block, appeared to be working ok...any information will be gratefull..thanks.
  • benny/9
    • 1964
    Originally posted by zetasprite1
    Hi to all,
    you can take your sat receiver/cam/card/ etc: with you on holiday you will need a dish mounting bracket on the camper van or caravan etc: or a tripod dish mount to set up on the ground when you stop. you also need a composs to find south to set the dish on the arc every time you change possition. you cant like at hope set it once and then it finds all the satellites. so apart from setting the dish on the arc or a satellite everything will work ok
    Please Read Carefully!
    • bosvelt
      • 262
      If you have a lidl/aldi(now & again) or maplin near you they stock sat systems that are portable they would do the job.
      Sky+ HD Spiderbox 9000hd TM 5400 ci+ 90cm dish motorised
