Possibly a stupid question?
  • leolion2177
    • Sep 2011
    • 17
    Hi Guys
    Hopefully not a stupid question. (probably is though)
    I have 2 dishes - one standard at 28 east - another at 13 east.
    I would like to add 16 , 19 and 26 (east) to my setup. (Preferably to the 13 degree dish)
    If my lnbs are currently correctly pointed where they should go is it possible to buy a pre-configured multi-lnb bracket with the new lnbs pointed to the new feeds so that I can simply go on the roof - clamp it to the existing without all the calculating / pointing / adjusting and hopefully falling off the roof that it would entail otherwise?
    All advice greatly received and appreciated!
    Leo
  • ramjet
    • 2995
    Originally posted by leolion2177
    Hi Guys
    Leo
    no , not possible
    and 13 + 16 + 19 only gives a 3 degree spacing so you need slimline lnb,s and narrow brackets, meaning that 16e will be the hardest to squeeze into your setup
    • leolion2177
      • Sep 2011
      • 17
      Originally posted by ramjet
      no , not possible
      Cheers - would it be possible if i dropped the 16e and if so any idea where to get it?
      • ramjet
        • 2995
        even without 16e its not possible to buy one preconfigured, it has to be aligned manually on your dish, and you wont get a lot from 26e in the uk either, but 13e and 19e will work quite easily in the uk
        depends on your make and model of dish as to what can be used, like an lnb rack or the 3 way ones that clamp onto an existing lnb and allow 2 extra ones. many types are out there so I cannot advise you on what to buy but check e bay for suitable types
        • leolion2177
          • Sep 2011
          • 17
          Cheers - only interested in football so AD Sports was all i wanted on Badr - thanks again for the advice
            ADSports equals massive dish so thats a no-no, i would hang fire at the moment for the football as the new rights where just issued and you can almost bet that Al Jazeera will get a hefty chunk of the matches for the new season.
            • leolion2177
              • Sep 2011
              • 17
              Guys thanks for all the advice - sometimes you can google so much and find so much contradictory info that its hard to make sense of it all.
              Might look into just 16e and 19e as funds and technical know how both very low - cheers everyone!
              • BigfatPaulie
                • Dec 2011
                • 203
                You could get a motor for ?40 odd... Cheaper than several decent lnbs and a bracket!
                Sent using Tapatalk
                • ramjet
                  • 2995
                  as kirsty and phil often say , location,location,location
                  its not possible to view every channel from every satellite from one spot on the globe
                  so here in the uk we have to check where the satellite beams are aimed at (footprint) and what size dishes we need for each satellite from a given location
                  so here in the uk we generally get 30w, 13e , 16e , 19e , 28e , 39e. as for the rest it always depends on location and dish size, but we are lucky to get such a lot of channels and satellites
                  but not ad sports without the humungous dish mentioned by digicon, but there again they may not get 28 east in the arabian countries
                  • leolion2177
                    • Sep 2011
                    • 17
                    On thinking about it - considering its only for football - probably cheaper and handier to go for something like ADMC streaming for anything I cant get on hotbird (which is admittedly pretty rare)
