what beams are impossible on a 1m motorisied in wakefield as i am trying to figure what best to input in the tp updator spreadsheet
what beams are impossible on a 1m motorised in wakefield
Tags: None
Should be able to get 30w (nothing very good on anything till you get too) 0.8w,4.8e,7e,9e,13e,16e,19e,23e(only some transponders)26e,28e,39e,42e
If you get all them sats your dish is lined up okIf you tremble with indignation at every injustice then you are a comrade of mineComment
click over what sat you want you should get most available with 1m dish if not too far up north
SatBeams - Satellite Coverage Maps - Sat Footprint Astra 3A / Astra 3B / Thor 2A (Thor 2)Comment
That charts bollocks tbh
i can get ones on there it says i cant look at this guide its old but not much has changed it gives you the size dish you need
Hi. Why dont you be adventurous like me. If you have a motorized system then just go onto each satellite one at a time and do a blind scan. It will tell you if dish is aligned correctly and also which sats you can pick up. You cannot beat a blind scan for accuracy as its scans satellites from top to bottom. As mentioned already charts are not always accurate or up to date ; blind scans will always be accurate as it reflects the way your system is set up.
Regards.Comment
I have a list in my phone and I do pick up all sats meantioned above but what I wanted to no was what are the beams called o can't get for example 26e can get badr4 but not badr 5 or 6 so no need to scan 5 or 6 can just scan 4 just was wondering if was same for some other sats around the arcHi. Why dont you be adventurous like me. If you have a motorized system then just go onto each satellite one at a time and do a blind scan. It will tell you if dish is aligned correctly and also which sats you can pick up. You cannot beat a blind scan for accuracy as its scans satellites from top to bottom. As mentioned already charts are not always accurate or up to date ; blind scans will always be accurate as it reflects the way your system is set up.
Regards.
Company called pnm satellites a guy called Paul who is no help at all and is after sale servise sucks and is no help what so ever he even stole my old sky dish after he took it down to put motorised up wouldn't have minded if he asked complete t***serComment
HI GUYs yeh i found i can get 26e up easy but cnt get a sniff of 7w ;( wish i could
and thanks bugaloo am aware that i cant get them and can only get badr 4Comment
My 1m funke dish is still set up on my house in wakey, I'm just down in nz at the moment, up until august last year I could get a good few channels out of 7w. The new bird was much stronger, I also had a 1.25 ground mount dish set up in the back garden and I could get some 500+ channels out of 7w. I think megasport on 4.8w was more difficult. NTV on 24.5w is also a good one to try for.Comment
