sky dish no signal help
  • Panther785
    • Aug 2012
    • 79
    my dish has lost its signal, i have bought 2 new lnb also a sat meter and still no luck, the lock indicator is OK and the quality and strenght bar just flicker and they go and come back also the lock indicator does the same it go to ok then not locked.
    can any one help, i am not a customer of sky will they still charge me ?65 even if i am not registered to them??
  • ramjet
    • 2995
    either you fix it yourself or you pay for somebody else to do it
    obviously sly will charge you if they were to come out and fix it, but as a non-customer they may decline
    any satellite or tv aerial engineer could do the job, but its fairly simple to do it yourself using a satellite box to check signal and quality, and its probably not far out anyway
    • joetwizzy
      • May 2011
      • 322
      Could be a break in the satellite cable? Or you're boxes tuner could be on the blink? Worth trying another box, if still nothing then I'd replace the satellite cable.. Or at least try it with some new cable through a window to see if that's the problem. Seems unlikely to be your Lnb as you say you have had 2 so only other problem will be "is it pointing where it should be".
      • Nutsandbolts
        • Oct 2011
        • 1168
        Hi Put on a channel and move dish slowly left and right and up and down. If you get a picture then dish is loose and needs to be retightened etc. If no picture then problem with cable/LNB or box. If you are in London i could save you 65 quids.
        Regards.
        • Dr Doom
          • Feb 2013
          dodgy cable
          Hi,
          I had a similar problem and it turned out to be a cable problem. The cabling was over 12 years old and the outer sheathing looked cracked!. Got a local guy to replace with higher rated cables and hey-presto.
          Good luck though. :-)
