Hi friends, I've updated Amiko miniHD firmware but after the reboot it is blocked, are you met this fault? Thanks
Amiko miniHD
From what you explain it sounds like the video resolution setting/output has changed somehow with the update of firmware so it's now not suitable for your TV (hence no picture).
There are two ways to cure this, one is keep pressing the v.format button on the remote control which will scroll through different resolutions, once one that's suitable for your TV is selected then the picture should appear on screen, just don't be to quick to press the v.format button one after the other as the switching of format can take a few seconds at a time.
The second option is to connect the receiver up via the A/V out to a TV, this way you should get the picture straight away and can head straight into the menu and change the video resolution settings accordingly.Comment
