sky HD channels
  • paulmeeke
    • Feb 2013
    • 7
    sky HD channels
    well i got my new motorised dish finally setup with my vuplus ultimo.
    I am having trouble getting the sky uk channels? when i do a satellite search i brings up all the french sky channels but not the uk ones?
    What am i doing wrong?
  • ramjet
    • 2995
    its not pointing at 28e when you do the search if it gets anything other than uk channels
    make sure its actually pointed there before attempting a search
    • paulmeeke
      • Feb 2013
      • 7
      damm i was at it all day yeasterday trying to get this sorted. thought i finally had it..
      done everything as said. pointed motor true south and sorted elevation and dish angle?
      seems i will be back at it after work.
      • paulmeeke
        • Feb 2013
        • 7
        i will say it is moving across and picking up satellites? surely it would have to be correct if it is going into other satellites?
        • ramjet
          • 2995
          suggest you do not mention a certain uk provider too
          nudge nudge
          ensure your motor points true south which for the uk is usually uing 0.8w or 5w for reference, but for usals can be any satellite really
          then make sure your usals settings are correct for your location
          once you have signals, peak them and ensure you get FTA channels on each and every satellite. use a catseye list or similar and check cbs action and bbc1HD and other fta channels like the vault on 28e to ensure you get the correct satellite, concentrating on fta channels from each satellite, not a certain uk provider
          once you can step through the sats and can see and hear fta channels that are correct for each position, only then have you set it up correctly
          therefore you cannot get french channels when on 28 east as they are uk and english speaking for the most part, including bbc and itv channels
          french channels tend to be on 13e hotbird but there are some on a few other positions too
          so if it is stepping between satellites , select 28e, and try cbs action , bbc1HD and itv, if they work its correct, but any "foreign" language channels would mean its not even pointing at the correct satellite
          • brin251
            • 122
            sky
            nudge nudge
            Do you get uktv bbc1 etc if u do then get someone to look at your dish to see if it moves when u goto sky from uktc it should move 1 inch only my guess is you will move 15 degrees west to 13e lets know how u get on
            Brin
            • paulmeeke
              • Feb 2013
              • 7
              i will have another play about with it tonight. will post up what channels i am getting on supposed satellites.
              • andy91
                • Aug 2010
                • 3583
                Double check your long and lat if its wrong you will be picking up the wrong sat Put your full address and postcode into dish pointer.
                Andy
                • ramjet
                  • 2995
                  its also worth noting that there arent any french sly channels, there are german and italian and uk on 19e and 13e and 28.2e respectively but france uses canal plus and other broadcasters and is generally 13e and 5w
                  • paulmeeke
                    • Feb 2013
                    • 7
                    Well ive almost got it sorted. Got the astra satellite 28.2e getting all my bbc and itv channels so def on the correct satellite. Checked my elevation settings on the motor and it is all correct. The dish angle i just fine tuned when i got the astra satellite. i can move to astra 19.2e and get a full signal 99% but moving the other way 13e i get nothing, when watchin the signal as the motor is moving to this sat it seems as if it goes past the sat, as signal jumps up then dissapears.
                    • andy91
                      • Aug 2010
                      • 3583
                      Put Catseyes bouquets on there.
                      Andy.
                      • paulmeeke
                        • Feb 2013
                        • 7
                        Andy.
                        So i just download the catseyes settings file and put all the files into the /etc/enigma2 folder on my vuplus ultimo reciever? should i delete all files that are currently in that folder?
                        • ramjet
                          • 2995
                          a new channel list overwrites the current one
                          back it up if you need to do so, then load in the new list
                          use vucc , or dreamboxedit or dreamset
                          it will also be on the plugins server in some or most images in which case you download it
                          • andy91
                            • Aug 2010
                            • 3583
                            Load them using dreambox edit.
                            Theres a guide on here and do it on your laptop.
                            Andy.
                            • paulmeeke
                              • Feb 2013
                              • 7
                              My laptop runs ubuntu so dreamboxedit can be a pain, hevent looked into it too much yet. My vuplus box runs the blackhole image so i am sure it has this catseyes plugin in it somewhere. will have a look about for it.
                              Am i reading right that my dish is setup correctly but as it seems my vuplus is moving to motor to the wrong position for some of the sats? and this catseyes plugin will help it in giving the correct position of the satellites?
                              sorry if i seem like a total beginner in this.. but that is because i am
                              i do appreciate all the help i am getting here
