mgcamnd
  • iain66
    • Dec 2010
    • 52
    mgcamnd
    What is the best version to use on an e2 box please
    Thanks in advance
  • chic.
    • 1599
    mgcamd
    hi m8 i use 1.35a without any problems
    if i helped hit the thanks btn
      There is also 1.38 and 1.38c which had uodated config to incorporate the hack for the JSC channels
      • ab25657
        • Mar 2013
        • 13
        Guys,
        Hope you dont mind me hijacking this thread. I have recently got a Skybox f3, but am wondering the following:-
        Is it possible to put the config files from this box and move them to a twin tuner so that we can watch and record at the same time
        Which twin tuner is the best?
        Is it possible to put mgcamd or any other cam onto *any* PVR box, for example Icecrypt T2400
        Thanks in advance,
        Adam
          Hi Adam,
          Please dont try and hijack other peoples thread you would be better openeing your own in the correct section so that you benefit from more replys to your problem. Please have a look at the rules before you post any further: http://www.digital-kaos.co.uk/forums/f5/forum-rules-2/ Thanks
          as for your question all other receivers have there own version of mgcamd and most are not interchangeable, all you have to do is retrieve the so called DATA that is held within the cam file and transfer this DATA onto your new box and everything will work fine.
          The DATA i refer to is what is letting you so called view at the moment we cannot discuss this in great detail as you will find out when reading the rules.
          Regards
          • mdt
            • 3034
            oscamYmod is a better cam emulator for running softcams imo although if wanting it for N then 1.37./1.38... regards mdt
