dish size for Hotbird help
  • total newby
    • Feb 2011
    • 183
    hi im lookin for advice on a dish and lnb type for hotbird, iv seen dishes on ebay 100cm with no lnb for ?50 deliverd but has no lnb are these dishes sutable? also what lnb would do the job many thanks alan.
  • djpopeye1971
    • Apr 2010
    • 165
    check the 3 sats on one dish posts took me a while but if you have meter and 80 cm dish you could do that
    • ramjet
      • 2995
      if you are uk based then almost any dish will do the job from 40cm upwards but I would suggest a zone 2 60cm sly dish or similar size or bigger and use a universal lnb
      so for the uk a zone 2 sly dish with sly lnb would work and would be the cheapest I would think due to the plentiful nature of them and availability
      any size bigger than that will work but is overkill
      • BigfatPaulie
        • Dec 2011
        • 203
        Re: dish size for Hotbird help
        I'm in the Midlands, and get hotbird on a standard sky minidish!
        Sent using Tapatalk
        • djpopeye1971
          • Apr 2010
          • 165
          i did what digicon did 3 lnbs on a zone 2 sly dish its mint
          • andy91
            • 3583
            Amazing if you browse the forum what you might find.
            Andy.
            • mdt
              • 3034
              Sent using Tapatalk
              you get all transponders in all weather on a zone1 mini-dish?
              OP if you want reliable reception of all channels from 13 east get yourself a quality dish and lnb like the triax td78 and inverto black ultra... granted a zone2 will suffice but imo its best to buy quality components now as you may want to upgrade in the future. regards mdt
              • djpopeye1971
                • Apr 2010
                • 165
                i did what digicon done i look forward to the future and a dish up now may not we what we are using in a year or so
                • mdt
                  • 3034
                  your dish is a generic triax td78 copy m8 not a zone2 mini-dish although id choose yours over the zone2 myself. regards mdt
                  • total newby
                    • Feb 2011
                    • 183
                    thanks for the comments iv got a standard sky dish at the moment oval mesh type around 60cm, i pointed it at the hotbird sat with the meter and got it spot on, but only getting about 14 chanels , any ideas? im in scotland uk
                    • ramjet
                      • 2995
                      make sure its got a universal lnb on it
                      if it was an old dish with the analogue lnb, the lnb would need changing
                      but if it worked with sly digital and all the channels on their box it should work on hotbird
                      • mdt
                        • 3034
                        are you sure you are on hotbird? can you name some of the 14 channels? even with a old analogue lnb of 10ghz you would still get more than 14 channels. regards mdt
                        • gerrywac
                          • Mar 2013
                          • 21
                          I've just bought a Skybox F3 receiver and as my motorised dish is U/s hooked it up to a cheap 40cm camping dish and several year old "no-name" Universal LNB, for a quick test set up with a meter
                          Pulled in 400+ FTA channels on Hotbird at varying qualities. I'm in Leeds West Yorkshire
                          My normal dish was a 50cm on a Technomate 2300 motor ha pulled in numerous sats an more channels than my old box could handle
                          I know Scotland is further north but 14 seems a bit low
                          Gezz
                          • jr250
                            • Dec 2012
                            • 7
                            I can get plenty channels on Hotbird with a 88 cm dish and I am way up the North West of Scotland.
                            Protek 9760HD ip
                            Triax TD88
                            TM-2600 Super
