hi all, is there any difference in 23.5 3a and 23.5 3b because i seem to be missing alot of channels that say 23.5 3b on lyngsat and on my tm5402 it says 23.5 3a. basically im getting all fta and sky channels nothing else?
23.5 3a and 23.5 3b sats?
Your last sentence confuses me somewhat.
Can you confirm which satellite you are on as there are no S*y channels on either 23.5a or 23.5b. -
Hi. In my TM5402 the satelite at 23.5 east is called 1D3A. You can get groups of satellites transmitting from the same orbital position ie HOTBIRD 7,8,9,10 etc from 13 east. What are some of the channel names you are getting as i suspect you may be on the wrong satellite. Also do you have a motor and if so are you using USALS or 1.2??
Regards.Comment
Yes that is correct the satellite is called 23.5 1d3a and I'm using usals. I'm getting 560 channels which as I say are mainly fta and sky channels ie, sky sports,sky movies etc. I'm also confused :/Hi. In my TM5402 the satelite at 23.5 east is called 1D3A. You can get groups of satellites transmitting from the same orbital position ie HOTBIRD 7,8,9,10 etc from 13 east. What are some of the channel names you are getting as i suspect you may be on the wrong satellite. Also do you have a motor and if so are you using USALS or 1.2??
Regards.Comment
Hi Satj. As i suspected you are on the wrong satellite. Its looks like you are on the Sky satellite at 28.2 called FREESAT. Your dish is out of aligment by around 5 degrees. On Freesat i normally get over 800 channels using a blind scan. If using Usals do you get other satellites like Hotbird 13 east and Astra 19.2 east as i dont think you can if you are 5 degrees out. What motor do you have?? Please let us know if you have problems with other sats and if you do it can be resolved by re-aligning the dish or maybe changing your Usals settings.
Regards.Comment
last post was correct, you are aimed at the wrong satellite which means there is something wrong with the installation or settings as its 5 degrees out. there should be no sly channels on that satellite position so the fact there are means you arent pointing the dish correctly
you should receive the fta channel tv noord on 11914H 27500 when its pointing at 23.5eComment
Hi satj. I am a bit confused as to what you are actually using ie USALS or 1.2. If you are 5 degrees out then USALS will be out on all satellites. You motor is going too far for the east sats and too short for the west ones ie 1 west will stop at 4 east and 5 west at 0 etc etc.
Regards.Comment
