Newbi question here, I have my full sky package for my sky+ boxes what happens if I put the cad in my F5 Skybox could I watch the same channels or do sky need to pair card with my box, also has Ccam settings 6.57 and 3.57 mhz in clock setting whats that about,if I put it in other box would it damage it?
Sky+
Yes you can use your card to view subs in your openbox.Newbi question here, I have my full sky package for my sky+ boxes what happens if I put the cad in my F5 Skybox could I watch the same channels or do sky need to pair card with my box, also has Ccam settings 6.57 and 3.57 mhz in clock setting whats that about,if I put it in other box would it damage it?
On your sky box go to Services, select Settings, press Down button and select Details......
This will show your card-cam 10 digit serial number.
Take the 10 numbers and convert them to hex in Windows calculator......
(if your serial begins with any zero's these will obviously not show when you put em into windows calc)
Once converted to hex........This will give you an eight digit number (if less than eight then put zero's in front to make it eight)
This number will be used inyour openbox as your boxkey..
