Problem with motorised dish
  • redrage
    • Jan 2013
    • 16
    Hi all, Got a huge problem if anyone can throw some light onto this please.
    My motorised dish has gone to its end, stops and will not come back regardless of what I do (go to home position, move motor, ...). It is now pointing well East at a strange angle (like downeards) and I can receive nothing.
    Has anybody had a similar problem or know what I can do to fix it (short of a big hammer).
  • andy91
    • 3583
    If your using usals im guessing it will still move when you select a channel but it has to be on the correct arc to hit the sat you want to watch.
    What box is it on and how are you adding the long and lat?
    I did post something in another thread earlier after you mentioned your problem.
    Andy.
    • benny/9
      • 1964
      if it's a dark motor a lot reported that happening
      also have you tried to zero the motor with the buttons
      under it.
      Please Read Carefully!
      • redrage
        • Jan 2013
        • 16
        Hi Andy,
        Thanks for your reply. I am using a vu+ solo 2, it wants to moves and when it tries to move it moves about and inch or two then stops and will not go any further. I have also tried another box but the same happens. I added the long and lat on tuner setup
        Mark
        • redrage
          • Jan 2013
          • 16
          under it.
          Hi, yes i have tried using the buttons on the motor, b ut again it moves an inch or two and stops and the red light comes on
          • andy91
            • 3583
            Hi Andy,
            Mark
            Are you 100% certain lat and long are first correct and have decimal point in the correct place?
            Found this courtesy of Dick B from another thread it might help you.
            cheap sat meter wont tell you what sat you are on.as your box has a satfinder menu use that. if using USALS make sure your correct long/lat are in the box and the same lat is set on motor. send the dish to 1West then put 11.682 H 28000 in your sat finder menu with 1West as the satellite.then starting off with the whole motor/dish assembly pointing roughly south and the dish elevation around 22 search for a signal by moving the whole lot L/R and the dish elevation only up/down til you find the signal. sweep slowly left/right then move the dish up a bit at a time if unsuccessful move it down a bit at a time and you will get it in the end.if you would rather use 28.2 East as your target its just as good but start off pointing in the same direction as sky dishes and make sure an active TP is set.
            ps dont forget to scan after you have found your target sat.
            __________________
            Andy.
            • BigfatPaulie
              • Dec 2011
              • 203
              Re: Problem with motorised dish
              Has this motor and box Ever worked correctly together?
              Sent using Tapatalk
              • redrage
                • Jan 2013
                • 16
                __________________
                Andy.
                Thanks Andy, I will give it a go
                • redrage
                  • Jan 2013
                  • 16
                  Sent using Tapatalk
                  Yes mate, it has worked although briefly
                  Mark
                  • andy91
                    • 3583
                    If the lat and long are out you wont see shit,
                    Post how youre putting them in,
                    Andy,
                    • redrage
                      • Jan 2013
                      • 16
                      Andy,
                      Under tuner configuration
                      Mode:Positioner
                      Longitude 003.004 West
                      Latitude 051.365 North
                      Mark
                      • andy91
                        • 3583
                        Mode:Positioner
                        Mark
                        My Long is East but im guessing where you are give it a go.
                        Andy.
                        • redrage
                          • Jan 2013
                          • 16
                          Andy.
                          Still no luck but thanks anyway
                            can we determine what type of motor the OP has installed
                            • redrage
                              • Jan 2013
                              • 16
                              New horizons diseqc nh-210
