Blade Bm7000s channel list install help
  • Scottyboi
    • Sep 2011
    • 30
    i have downloaded 2 channel lists from the download section but when i go into downloads on blade with usb plugged in its not showing anything. anyone know why? probably something silly (me being a dummy)
    You can use any of the Channel lists for the TM5402HD that are scattered around the forum.
    • Scottyboi
      • Sep 2011
      • 30
      ive got the list downloaded onto my usb but when i go into utilities - download nothing shows up
      • bj1
        • 445
        Have you format your usb stick if you have then try downloading another file,
        It will show up in utilities if the usb drive and file are valid,
        If you are just after 28.2 then you can always download from blade online on your menu
        • Scottyboi
          • Sep 2011
          • 30
          formatted to fat32 then downloaded new list but still not showing up. regarding blade online list, i was after a sky channel list really
          • bj1
            • 445
            Yes m8 select uk astra 28.2e on blade online then select your region .....central. hey presto
            • ramjet
              • 2995
              make sure your stick is fat32
              make sure you have unpacked any list if its packed in zip or rar
              the list should be ndf
              quite a few lists exist on here with an emphasis on 28.2e so do a search for one, like the happy highlander one
              • Scottyboi
                • Sep 2011
                • 30
                thats the one ive been trying to use (happy highlander). think ill retry tomorrow, had enough for one night. thanks for all the replies
                • ramjet
                  • 2995
                  sounds like you did not unpack it first then as they unpack ok for me
                  • Scottyboi
                    • Sep 2011
                    • 30
                    You must be correct because I have no idea what your talking about
                    • ramjet
                      • 2995
                      use 7zip and unpack the download and put the ndf file onto your stick
