I have a sly box in France. The problem is I seem to be getting a good signal with both quality and strength varying from 75 percent to 90 percent. However I still can not pick up quite a few of the channels. BBC being the main one, there are quite a few others such as ITV4, but I can receive ITV4+1. I have a 60cm dish but I can not see if fitting a larger dish will give me a better reception as the signal at present seems quite high. Any ideas?
Sat Signal in France
what reciever are you using?
where abouts in france, north or south?
as the fta/ftv channels are on a very narrow beam pointed at the uk to stop them being viewed outside the uk, so if in southern france could be signal relatedPS3= krazylegz120282
if you like what people say please use the reputation or thanks button, dont just make a post to say thanks -
Reported around 80cm - 90cm for this region. LNB skew is just as important in fringe reception areas. Local knowledge is always best.I have a sly box in France. The problem is I seem to be getting a good signal with both quality and strength varying from 75 percent to 90 percent. However I still can not pick up quite a few of the channels. BBC being the main one, there are quite a few others such as ITV4, but I can receive ITV4+1. I have a 60cm dish but I can not see if fitting a larger dish will give me a better reception as the signal at present seems quite high. Any ideas?Comment
