according to kingofsats multiple channels in red denoting a change of something,no harm i did a rescan so ready for the return leg +extras
Thanks again for your help. I get confused when doing a rescan...is there any way to quickly overwrite the old channel that I have stored, if it goes to another TP? I have to sit manually and go through the list and look for duplicate names, and my list is now so long its a right pain....
Any help on doing this would be much appreciated.....as I want to be ready for the off when they all apprear again!
Hi meerkat. Not familiar with your receiver but why not try one of these option:
1) Save your current channel list to USB if possible. This is in case you have problems you can restore back as it was.
2) If motorized switch motor setting to OFF to stop dish from accidently moving.
3) Delete all TP's. These will get rid of all unwanted channels as well as the good ones.
4) Do a blind scan and retune all TP's again. When blind scan completed check all ok. If completed ok dont forget to set motor
setting back to USALS or 1.2 etc.
5) If you dont wont to do a blind scan ask a member for a copy of an up to date channel list for your model.
6) When deleting channels you can use the A-Z button to make it easier to delete duplicate name channels.
select hotbird from the list of sats,if you only have hotbird then go down to the the start and press ok it overwrites your last channel list,with so many channels moved there are to many to delete,as of 1 hr ago said channels still off
always best to auto scan your chosen sat for so many moved channels,for moved ones say 4 channels you can delete those and add a manual scan with new info from kingofsat.
try this list mate fav 1 is films and ent fav 2 is sport and doc fav 3 28.2E and the one you want fav4 is xxx just download list un pack it load onto usb stick put stick in protek9760 then Menu>system information>"load channel list from usb">ok it will then over write whats in your box and reboot. if you save your existing channel list you can put it back in if you dont like mine(which is a personnal preference.
