Can I use my PC to view channels with OSCAM, CCAM, etc ?
  • Blizzarduk
    • 27
    I have a FireDTV firewire box for my PC, which is essentially a satellite receiver connected via firewire, however I may get a internal satellite box. Can I get a card reader for my PC that uses CCam or OsCam or something ? So I can put my Sly card in the slot and view Sky channels on it ? Without having to get a separate CAM ?
    I am a bit confused, as devices like this exist : Satellite Smargo Smart Card Reader but do they work on their own or in conjunction with my FireDTV ? Do they use CCAM etc ?
    Or this device too : http://www.pulsat.com/products/Smarg...le-Reader.html
  • ITS A SCAM !
    • Oct 2008
    • 1140
    I use to have a Technisat Skystar HDTV satellite PCI card in my PC, also I have a Technisat CAM interface in the same PC.
    By using software called "Hadu" I was able to view channels without the CAM interface, but with the CAM interface I was also able to view additional channels because inside the CAM interface was another device called a "Diablo" CAM ( confused ?? I am )
    To be honest you are wasting ??? on hardware that can only work if your PC is switched on, you will be much better off getting a Linux based set top box and only needing a PC so you can programme the set top box to open channels. There are subjects we cannot talk about openly on here, so PM me if needed..
    • Wale04
      • 44
      Hi DK,
      Having same problem and i will be happy if you could PM with the suggested alternative.
      Regards
      • thatfellow
        • Apr 2012
        • 17
        I use a TBS 6984 Quad DVBS/S2 Tuner Card with DVB Viewer & Hadu Plugin with a cline to my server.. Works a treat!
        If it's working perfect, take it apart to see why!!
        Dont be Shy. Remember to use the Thanks button.
        It is just Good manners & it makes ppl feel Good
