hi how do i add a new sat to the 5402 super sat list any help would be much appreciated
adding new sat
1st check its not already in data base.Menu>installation>satellite setup>ok then ok again and scroll up/down tosee if sat there if it is yellow button"save" this should put a tick against it,exit co to motorised settings drop to "go to" wait for motor to stop and scan.
if sat is not there it can be added ok just abit more complicated get back with name of sat and we will try and sort it. -
1.0W and 0.8w are virtually at the same position and classed by most boxes as the same some just calling it 1.0W some 0.8W and some splitting them up into the 2 different sats.all you need do is scan any TPs you want into the 1W slot and youll be ok.
0.8W is thor5/6(2 sats) 1W is intelsat 10-02.(1 sat)but for practical purposes they are classed as the same position.so what I"m saying is you already have the sat you want installed in the box they have just called it 1W.
your sat name is out of date thor 2 is gone(so has 3 Ithink)Last edited by dick b; 10 April, 2013, 15:58.Comment
