My Redline ts300 was working perfectly when I switched it off (into standby). A few hours later I switched it back on only to find the tv screen totally blue, ie no image of any sort. But the sound was OK and changed as I changed the selected channel using the handset. A cold reboot made no difference - there was still the totally blue screen. The tv was working properly and gave good pictures from my terrestial stb and from a different satellite stb. I switched off the Redline using the switch at the rear of the box (ie removing any power input). The following day I switched on as normal and the Redline performed perfectly. Any ideas as to what caused that interuption of visual output? Could it happen again and is it a warning of trouble ahead?
pibeta
pibeta
