Multi sat on a 65cm dish
  • Shady
    Shite Link King
    • Dec 2010
    • 6404
    Ive got hold of this 65cm triax dish. I reckon ive got good LOS from the bottom of the garden and was thinking about a multi lnb set up. 28.2E is a must. Is 19.2e worth having? what other sats should i try for?
    In Tamworth Staffs
  • ramjet
    • 2995
    Originally posted by Shady
    Ive got hold of this 65cm technomate dish. I reckon ive got good LOS from the bottom of the garden and was thinking about a multi lnb set up. 28.2E is a must. Is 19.2e worth having? what other sats should i try for?
    In Tamworth Staffs
    should be ok with 19e and 13e as well as 28e which are the main 3 , also possibilities of 16e or 23.5e or 39e too
    • Shady
      Shite Link King
      • Dec 2010
      • 6404
      TRIAX TD MULTIBLOCK 4 WAY MULTI LNB HOLDER | eBay was going to get this to use with 4 lnbs.. so you recommend 19.2e? 19, 13 and 28.2.. and you say i might get some others? 16 worth having?
      • ged47
        • Apr 2013
        • 81
        need to watch the degree space between lnbs, 16e and 13e are right up against each other, 28.2, with 19e and hotbird at 13e is the norm. i got a triax 4 way(but only 3lnbs) with track and brackets, and 4 way disque switch. ?15.
        Smile don?t frown, Look up don?t look down, Believe in yourself, Don?t let yourself go, Just be who you are And let your life flow.
          On a 65 you should get 28.2?, 23.5?. 19.2? and 13? dont expect miracles on weaker birds on 13? and 28.2? especially Eutelsat 28A for that size.
