Hi there,
I plan on beginning to install a 1m motorised dish installation this coming weekend.
I have had a good read of the sticky at the top which has given me great help and encouragement that i might just be able to pull it off!
The following link is a picture of where i plan to install, i plan on installing it as close to the existing dish as possible
which brings me to my first question, will it be ok being close to that, or should i be aiming halfway between the existing one and the chimney stack.
I have t&k brackets, and a 1.5m 51mm diameter scaffold pole to mount the dish on, i have very strong bolts for fixing the t&k brackets to the wall. I do live on a windy site, and the dish is solid, so I am worried that it might take a bashing at times. Any advice on this?
Next question is as regards the bits that have come with my package, I am slowly piecing them together in anticipation of getting a good run at it come the weekend,
Am i correct in following the picture linked below:
My bits are slightly different, but I am assuming the above is correct for what I am trying to do.
Actually below is my bits and pieces, I think I may have the bit circled on incorrectly?
Am i right in thinking i will be leaving that loose, and then adjusting it when up there to achieve the strongest signal when I am trying to find 1W as in the sticky.
I have a Vu+ Solo, currently installing the latest Black Hole image, and intend to use the methods outlined in the sticky.
Anything I am doing wrong or should be aware of,
In case it matters I am located in North East England, I have already worked out the lattitude and longtitude, and have an idea where i should be pointing it based on the dishpointer website.
Thanks for reading.
Thanks for reading.
