Dual tuner & good EPG decoders
  • holmesju
    • Apr 2013
    Hi everyone
    I'm quite new to this forum and need a bit of advice. I'm currently using a SKYBOX F5 which I am quite impressed with but I seriously miss the abillity to record and watch different programs and the EPG is absolutely rubbish. Could anybody recommend a good high end decoder with dual tuner and a decent EPG that will run cccam and mgcamd lines. many thanks
  • ramjet
    • 2995
    Originally posted by holmesju
    Hi everyone
    you need a twin tuner box for this and the only ones I would recommend from experience are the vu boxes, like the duo or the newer solo2, and I wouldnt touch a clone either. there are others that are similar and cheaper if you have a read through the forum here, like technomate and amiko
    you also need 2 coaxial feeds from your lnb too
    as for the epg , now and next is actually the correct standard on most broadcasters, so the boxes you need are the ones that can download a better epg than the standard one on your slybox
