13E on 60cm dish
  • deanlecky
    • Aug 2012
    • 48
    13E on 60cm dish
    Can the generic 60cm skydish pick up 13E signal? Based in N.Ire
  • ramjet
    • 2995
    should work fine, check the thread by shady as lots of useful info in there due to him trying the same thing
    • mdt
      • 3034
      here are the footprint maps for all 3 birds which show a 50DB downlink level in your area which means a 60cm dish is large enough with a slight weather margin although personally id go with a larger dish if possible to cover very heavy rain storms as you could get problems with a few of the weaker split txp,s on there,regards mdt
      Ku band (Universal LNB with noise figure of 0.7dB). 50dbw = 60cm
      regards mdt
      • deanlecky
        • Aug 2012
        • 48
        Cheers mdt. Quick question on your setup tag, ORBITAL 80CM [email protected]/19.2E/13E, how have you done this? triple lnb bracket or motorised?
        • mdt
          • 3034
          triple lnb bracket... regards mdt
          • ramjet
            • 2995
            similar to this http://www.digital-kaos.co.uk/forums...set-up-334542/
            • gracieboo
              • Dec 2010
              • 368
              Hi there im from norn iron so the answer is yes not a problem to get 13 east on a skydish. Ive had 39 east 28 east and 19 east on a skydish and also had it with 13 east 19 east and 28east all working fine, and as the rest have advised theres nothing more i can add accept goodluck.
              • blueflash234
                • Mar 2009
                • 904
                i have a 60 gibby with a mono block lnb and have 13 and 19.2 booming in,am in the midlands
                • deanlecky
                  • Aug 2012
                  • 48
                  Hi mate, would be very interested to know what bracket you used that fitted the arm on the skydish, and what lnbs worked best for you?
                  cheers
                  *Edit*
                  I've had a rampage around google, has anyone tried Inverto multiconnect lnb kit? Its looks very neat and says it fits any dish model. But pricey!
