BLADE 7000S
  • joe7710
    • May 2013
    BLADE 7000S
    Hello. I would like to ask a favour. I bought Blade 7000 s recently because of a good review in What a Satellite magazine. My problem is that I wanted to try to put c line to this receiver and I followed few manuals on other websites however it does not working for me. I used 9991 buttons to get into Server List and change protocol for ccam put a c line into address window and it is not still working. There is status in the server list and it is still disconnected. It might be this problem however I do not have a clue how to connect it.. I can not with cursor to this option to change that for connected. Is there any other way ? Thank you for your suggestions ...
  • ramjet
    • 2995
    make sure the blade is patched with one of the latest patches, like the jan 2013 patch
    connect to your router with a standard normally wired ethernet cable
    make sure the networking is on and the router can "see" the blade as an attached device
    try putting in your isp host dns`s in the primary and secondary dns sections
    it should show as green and connected when the sea lion is working
    • joe7710
      • May 2013
      Hi. Thank you for your advise. I have a software from 4 th of January of 2013 in Blade and it is connected with Ethernet cable. DNS and gateway, mask and IP address I am to see on the screen. Network is working but in server list where is ccam option beside it shows me that is disconnected.
      • ramjet
        • 2995
        check you have put in the exact name of the server , the correct name , the correct password and the port number too
        check lower case, upper case and any letters or numbers are also to be checked as one error will cause it to fail
        • dodgy dell
          • Sep 2011
          • 46
          Don't mean to sound silly but after you have input details of your 'Gift' you have pressed red to change active off to on?
