Sunray Sun800 HD se D6 setup
  • Ricey79
    • Dec 2012
    • 11
    Hi
    I have just received a new Sunray 800 SE box... There doen't seem to be any tutorial on setting this up. I have upgraded from the DM500 which had lots of tutorials
    Looking at the following link someone has posted the nemesis 2.5 link as a fully working image with wifi
    Nemesis2.5-Sunray sr4-e2-OE1.6-SVN104r4-drivers 16.02-ssl84b-sim210-by sat4fun
    Also from looking at the following link I can flash without buying a mini USB cable
    DM800 HD se Flashing firmware by Browser | dream-multimedia-tv.de
    Can someone please advise if I can flash this box from the browser and what I would need to install to get this running with EDIT cant talk about here
  • ramjet
    • 2995
    check the dreambox E2 section here on dk
    there is a full tutorial for setting up E2 boxes on the dmm website
    • Ricey79
      • Dec 2012
      • 11
      Thanks I found a link to a youtube video from here "Flash DM800 by DreamboxUK" was very easy to flash it over the network
      The only problem now is I can not find the cccam.cfg file and have checked loads of posts
      When I press the blue button I get the Softcams CCam 2.3.0 but can't find the config file to enable it, any idaes?
      • andy91
        • 3583
        Press blue button if it says common interface press up and down till it says CCcam 2.30. Cant say much more than that im afraid. Install TS panel that will also help, Andy.
        • Ricey79
          • Dec 2012
          • 11
          Thanks for the quick response, seems to be running CCcam 2.30 but I dont know where to put the magic numbers.. I created a CCcam.cfg in the /etc folders but doesnt seem to be working.. Tried several different numbers so not sure that's the right place for the cfg file.. There was no /var/etc as originally expected... TSpanel is not listed in my plugins
          • ramjet
            • 2995
            check your var/etc folder for the required file
            or download one and ftp it in and amend it
