Amiko Mini HD settings problem
  • BMWcare
    • 14
    Hi all,
    I'm having the following issue:
    Mini HD connected to tv with HDMI lead.
    AV output set to RGB. All works perfectly.
    If STB is put into standby it can be turned on again and the RGB setting is retained.
    However, if the STB is powered down (unplug it) and then power it up again then the AV output changes to CVBS and I have no picture on tv.
    Then I'm left with a problem. I must connect another tv to the AV out at box (using phono type jacks) to get a picture and then change setting back to RGB in the menu.
    Once this is done the picture returns on the main tv through the HDMI.
    Is there something simple I'm missing in setting up / saving the setting? Or is it a faulty unit? I even went into System Settings>Save Default which reported 'Success'. However once power was removed it was back to losing the RGB setting every time STB was rebooted...
    Thanks for taking the time to read this,
    E.
