How many satellites would I pick up on a 60 cm dish thanks
60 cm motorised dish north west
Tags: None
Was originally thinking of 80 cm think that do me best there is quite a big tree in my line of site so think 80 cm would be better option or would I need bigger due to this treeComment
No size of dish can combat a Tree in its line of sight you may have no problems in the autumn and Winter months but as soon as spring/summer your back to square one, your main aim here is to find another position on your property that has no LOS problems for a dish install
I pick up 13e, 23.5e, 30w, 28.2e, 39e and 19.2e with ease. I also pick up 16e but can be a bit shitty and some 7e but very little, all with 60cm dish in the North West. Didnt want a huge dish on the front of my house and find my set up more than good enough for what i want.Comment
I set up with an 80cm motorised. (In the Northwest as well). Get good signals off all the main sats. When it was on the ground the dish did look huge....but up in the air on the wall doesn't look that bad! No complaints from the neighbours! Thinking of upgrading soon to a 90cm...would make a lot of difference to the 'fringe' signals. I do have the advantage of a clear south facing view with no obstructions.Comment
im in northwest and trying to talk the wife into letting me put another dish up are these anygood NEW HORIZONS 60cm 65cm SATELLITE DISH DISEQC MOTOR + GOLD 0.1db LNB | eBayComment
cheap tat m8 as you get what you pay for although it will do a job on the strong birds@ 28.2/23.5/19.2/13/9/1/5/8/30... if you want to stick to a small dish then a triax td78cm,tm2600 motor,inverto black ulta lnb and L wall mount (T+K with small length of pole would be better but L bracket is fine for south facing wall with small dish) should cost around ?100 with 20mtrs of rg6,bolts,plugs and clips if you shop around. regards mdtDM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30WComment
?88 of the bay but you dont get the Black ultra which is no big deal really for the sats your going to pick up with it.
