Hi,
Today I installed a Triax TD78 with a Triax Multi LNB bracket. Firstly after fitting the dish I fitted the 19.2 LNB to the right of the dish arm butt up to the centre bracket and then I got the dish positioned until I found 19.2e using my sat finder, I then scanned for channels and got about 500, then using the signal meter pc program on the laptop I adjusted the dish to get maximum signal, which was about 90% SNR and 99% AGC. I then scanned and got over 1500 services.
I then fitted the 13e LNB with is touching the 19.2 LNB to the right of the centre bracket, I got about 75% SNR and 90% AGC on 13e with over 1500 services.
Then I tried to find 23.5e on the left hand side of the bracket but I cant find it, I found 28.2e but it was about 20mm higher than the bracket even with the bracket fully tilted.
Tomorrow I am going to remove the 19.2 & 13 LNB's and adjust the dish to find 23.5 and then add 19.2 then 13 see if that works any better. Has anyone got any other advice on what I could do to get all three satellites working?
Thanks.
Thanks.
