Blade bm7000 dish setting quality
  • Scottyboi
    • Sep 2011
    • 30
    Hi guys, was just wondering what I should be getting on the level and quality strength meters in the dish setting menu on my blade using a sly mini dish
    thanks scottyboi
    as high as possible
    • Scottyboi
      • Sep 2011
      • 30
      Great help thanks
        If you had wanted a more detailed answer then a little more information such as what channels at the moment are you or maybe having problems with and then let everyone know what firmware you are running on the receiver itself and how old is the channel list.
        This will Garnish a more Broader response, But my initial reply still stands your SNR should be as high as possible on most of the weaker Eutelsat 28A beam.
        The problem with the blade is when you are on a channel it just quotes the AGC signal and not the SNR whom ever thought of that idea in the Korean Factory should have been sacked
        • Rodbouy
          • Jul 2010
          • 1320
          Boxes will vary in signal strength. I have noted the 7000HD has a lower & than say 500 800 and duo. Its not a problem just get the highest like said above. Dont match signal levels to a different box.
