broken bracket
  • shaunfree
    • 358
    broken bracket
    hi all wonder if anybody could help please,my motorised setup moved over night,so went to sort it out 2day,went to tighten up onto pole but threads are gone on the square bolt (ubolt), and cant tighten up, googled to buy another but cant find anywhere,thanks http://www.digital-kaos.co.uk/forums...&thumb=1&stc=1
  • M T Glass
    • Jul 2013
    • 733
    Hi, I'm assuming the threads are gone further up the bolt towards the U bend, if so, put one or two larger sized nuts onto the thread to take up the slack at the damaged part and buy a new 8 or 10mm nut (whichever is applicable) and tighten up again. Or, buy a length of 8 or 10 mm threaded bar and nuts and cut off to length and bend in vice to U shape but run nuts up thread to be used to prevent damage while bending.
    Official Meat-Head Fan Club Member (member number 14300)
    • digicon
      • 8261
      even easier take the damaged bar out and replace with bolts from B&Q simple as that they dont have to be U shaped as they just clasp the elevation bracket to the pole, If i remember they are M8 with 13mm nuts.
      Its always advisable to Grease the new set before you install them
      • shaunfree
        • 358
        thanks M t glass and digicon,good ideas thought it was going to be a new motor,cheers much happier now
        • ramjet
          • 2995
          if you can measure the length of the actual bolt part, and the width between the bolts, on the broken U bolt, you may find them or similar on e bay
          check this item number for instance 321169993478 - 'U' BOLT ZINC PLATED WITH NUTS AND WASHERS - Size Approx 115mm x 70mm ?3.45p each
          'U' BOLT ZINC PLATED-TRAILER PARTS TO FIT,HORSE BOX,CARAVANS,MOTOR HOMES,BOAT
          or this one eBay item number: 251309046831 or 110947690944 or 120951407647
          • shaunfree
            • 358
            Thanks ramjet for the link, looked but not wide enough,otherwise would be ideal ,thanks for taking the time to look cheers
