Newbie: Protek MK-I
  • GazCheshire
    • Aug 2013
    • 7
    Newbie: Protek MK-I
    Hi,
    I'm new to all of this. Ive got a new receiver, i can get all the free / unscrambled stuff but cant get a lot of channels that are showimg a $ sign.
    My box is connected to my router, in plugins its says CAMD and thats it - anyone know where im going wrong, i dont know if its me, the bix or the software.
    Thanks,
  • ramjet
    • 2995
    depends what satellite you are pointing the dish at (you didnt say) - if its 28.2 east you wont decode anything with a $ sign
      You need to contact your supplier of the Box as the protek come with a so called 'Gift' for channels but as ramjet stated none for 28.2? east, you need the patched software or if it was supplied patched you need a motorised dish to make full benefit of it.
      • GazCheshire
        • Aug 2013
        • 7
        Thanks,
        Sorry, i do have a motorised dish, but nothing will work ( the "gift" etc ), is there a way for me to patch the box or update it.
          then you need to do a search for the patched software for the box, if it is not available on here then try google
          • GazCheshire
            • Aug 2013
            • 7
            does anyone know the name of the file or wherei can find it? i cant locate it...
              What model number is the protek box as the MK-1 was discontinued some time ago and could have had the Ethernet function disabled which means either source your own 'Gift' or buy another box
              • GazCheshire
                • Aug 2013
                • 7
                hi, im not sure of the model (not great at this) but mk1_apps_39q downloads and i have connectivity on my ethernet port.
                thanks for your help btw :-)
                • Dekka1974
                  • 10
                  My friend has a protek 9720HD box and a dish with 19.2 & 13 degrees and went off the other, I just turned off & on the router & the box and it all came back on. His box only has a gift for the channels available from these sats, don't think these boxes do anything else.
                    They do a lot more than just 13? east and 19.2? east i can tell you just nothing on 28.2? east
                    Model Number is on the front of the box
                    • GazCheshire
                      • Aug 2013
                      • 7
                      Hi,
                      It just says MK-I (looks like a capital I)
                        Ok i take its the HD version and if so how long have you actually owned it and was it working previously
                        • ramjet
                          • 2995
                          Originally posted by GazCheshire
                          Hi,
                          in post #1 you said its a new box
                          but those model details are from an old box that is discontinued and was made a few years ago, indicating its not new
                          Protek MK-1 HDTV Full HD Linux Satellite Receiver
                          Discontinued Product
                          The new Protek MK-1 is based on the unix 500 by protek packed with many advanced features and now gives the same support plus more including the best from HD TV.
                          linux based. The unit comes with a single DVB-S2 tuner, but you can always add a second tuner (DVB-S2, DVB-C or DVB-T).Not included.
                          So I think its the old mark one version that digicon mentioned was no longer supported - in which case it may be that it will only work with an n line
                          • GazCheshire
                            • Aug 2013
                            • 7
                            Ok,
                            Sorry - I have owned it for 3 days and its never worked fully, however it is a discontinued version.
                            When I say new, I mean never been used.
                              Ok,
                              Its probably had the Ethernet 'Gift' switched off by now due to the age with the proteks you can get anything from 12-48 months before they switch the MAC off at there end.
                              As Ramjet clearly stated you will now have to look for another 'Gift' to work with the box
