10E Transponders
  • shaunfree
    • 358
    10E Transponders
    hi all,i can get 10E with good signals (uk) but i was looking for wwe feeds 4 summerslam ,so found these, 11153 - Pol: H - SR: 6111 - FEC: 3/4 ,11140 - Pol: V - SR: 15000 - FEC: 2/3 ,11160 - Pol: H - SR: 15000 - FEC: 3/4 ,11171 - Pol: H - SR: 6111 - FEC: 3/4 ,the prob is when i put the transponders in manually i cant get a signal,should i be able to get these in uk,(using a 1m + motor+b,ultra lnb)
    Yes you wont have a problem but please consider this:
    1. when you try them they may not be switched on as they are feeds and are only live when needed which only the broadcasters know and no one else unless you keep staring at a blank screen for hours.
    2. Feeds are relayed from other satellites and downlinked to studios that have massive dishes so they dont have to transmit on full power so your 1m may be ok when its on and broadcasting at full power but if they half the power then you could find no picture as your dish is to small which is not a problem for the downlink studio.
    3. they could broadcast with BiSS key and or 4:2:2
    Just a little food for thought
    • shaunfree
      • 358
      hi dgicon thanks again mate,you must be right just tried 11140 - Pol: V - SR: 15000 and able to watch it now cheers mate,shaun
