Channel master/ Andrews dish mounts
  • windysat
    • Aug 2013
    Does anyone know where I could buy a mounting plate to fit a 1.2m Channel master dish onto a 1224 Jaeger H to H motor?
  • andy91
    • 3583
    Cant beat T&K brackets especially on a big dish like that, Andy.
    • windysat
      • Aug 2013
      Sorry if I misunderstood your answer, however the motor is already mounted on a 3'' diameter pole fixed onto a one ton concrete pour. What I require is the plate to fit the dish onto the Jaeger motor. I would build one myself but I have no 5mm stainless plate to play with at the moment.
        You would be better off having one fabricated for your needs by a local engineering firm, You could also try Ebay to see if any are for auction but the Jaeger Motor is in a league of its own and is very sort after even now.
        The only other option is to contact satellite Superstore and see if they can source one for you but at there prices it will not be cheap.
        Regards
