I did ask a similar question a few weeks back but didn't get even 1 reply I know the Xbox one is not out yet so the likelihood that anyone knows is slim, But maybe there are others out there that are as curious as I am. so iv hears that the Xbox one will be capable of connecting to Sly and virg boxes and the Xbox will sort out your TV guide etc. for you (you never need to change the TV over to the TV channel again just keep it on Xbox channel and use kennect to change channels via voice commands) if anyone knows anything at all it would be helpful even if is a simple no it wont work at all then at least I will know.. thanks in advance
F3 pass through To Xbox one
Is a box like the VU+ Solo that supports HDMI-CEC v1.4 likely to work with the one input? HDI Version 1.3 would require the addition of an IR Blaster along with the HDMI input (Auto or Manually Programmed - As long as you use bouquets that are numbered like Sky Channels).Comment
As an alternative to the Xbox 360 Media Center Guide. Every other dreambox/OpenBox/Skybox/etc guides look 2-bit in comparison.
The XboxOne Guide looks much useful and elegant...and why not use the functionality if its there?Comment
HDMI-CEC (Consumer Electronics Control) has nothing to do with the HDMI standard 1.4 all HDMI standards are HDMI-CEC if the devices connecting to them are all compatible.Is a box like the VU+ Solo that supports HDMI-CEC v1.4 likely to work with the one input? HDI Version 1.3 would require the addition of an IR Blaster along with the HDMI input (Auto or Manually Programmed - As long as you use bouquets that are numbered like Sky Channels).
HDMI standards changed quite a bit ago and are no longer referred to by the numbering system instead they are known as:
- Standard HDMI Cable ***8211; up to 1080i and 720p
- Standard HDMI Cable with Ethernet
- Automotive HDMI Cable
- High Speed HDMI Cable ***8211; 1080p, 4K, 3D and deep color
- High Speed HDMI Cable with Ethernet
I still highly doubt that any current 3rd party receiver will be compatible with the Xbox One as you would want it, In the future who knows
The XB1 UI is an overlay and the ONLY functionality the IR Blasters need are the ability to change the Channel (needs to be 3-digits & numbered like Sky) + Volume. Ideally I would've preferred it to act as an extender for my WHS Tuner(s)... but I'll leave them for the 360.... until a future software update allows it.Comment
