sky eye on vu box
  • pspmixer
    • Jun 2009
    • 750
    sky eye on vu box
    friends looking at getting the sky eye device where can watch what the box downstairs is playing to his upstairs tv, what are they called, where to buy and how to set also can they be set up on bt boxes and skybox f5 boxes thanks
  • ramjet
    • 2995
    sky magic eye - plenty on e bay , no they dont work on any box apart from a sky box (the proper sky official boxes, not the openbox-skyboxes)
    you can buy the adapters to make them work like the global or similar , try a search on these forums as its been discussed many times before at great length
    also, they are only used to turn the actual box over (they transfer the infra red commands so you can operate a box remotely over coax cable)
    they DO NOT send video and audio signals from your box to the remote tv
    edit
    to do both you need one of these
    TRIAX TRI-LINK KIT & MODULATOR 370407 - VIEW & CONTROL FREESAT/FREEVIEW/ SLY
    • pspmixer
      • Jun 2009
      • 750
      edit
      so that's scart output what about hdmi, what if tv connecting to only has hdmi output
        If your box does not have a scart output then it should have some form of analogue output such as Phone - Red,White,Yellow which you can purchase a phono to scart lead to use with the Triax tri-Link
        • ramjet
          • 2995
          a tv has inputs, not outputs, and every tv has a tuner or tuners inside it
          you are changing a scart or phono output into a coaxial rf signal the same as the sly box does, the tv has to have an analogue tuner inside it as well as a digital tuner, then you tune the coaxial rf analogue signal in using the analogue tuner on the tv to the rf incoming channel from the modulator (the same as is done on an official sly box distribution)
          the eye is used in the opposite direction to send infra red to the vu or satellite box to operate it (normally this is rf2 on the sly box)
          no hdmi or anything at all for this, just an rf signal converted from scart or phono at the box end and rf into the tv at the tv end (the vu boxes have scart and you can easily buy a cheap scart to phono adapter if needs be), with the magic eye also plugged into the aerial coaxial cable at the tv end
          • johnny yen
            • Feb 2010
            • 60
            ive got a duo and if u have a iphone u can get a app called dreaMote lite u can use that as a remote control over your wireless internet sure there is a android app too not sure tho
            • tony_i
              • Oct 2008
              • 425
              These are good. I've been using them for years.
              Mini 5.8GHz Video Sender : Wireless Video Senders : Maplin Electronics
              • BRASS EAGLE
                • 307
                i got a video sender which allows you to watch the tv any ware else in the house without having to lead wires alll over the place and it changes the stations ,i got it from asda its in the ONE FOR ALL range that they sell its a av wirless sender reciever , works great , it was on sale the week i got it for ?25 so i took a chance ,it was worth it , they sell now for around the ?40 to ?50 mark
                • flyingpig
                  • Aug 2009
                  • 930
                  I am sure with most boxes you could do it from your phone by logging into the web page of the box.... Saves all the magic eye remote control malarky.
