help blade glitching
This topic is closed.
  • diyingtime
    • 4
    I have had this blade 7000 for a while with no issues at all. I use a cs that gets good reviews and has had no issues. a few months ago I started getting constant glitching which also caused lipsync issues. I then subbed to another cs on recomendation from work mate but still get issue. The issue is slightly diff between both cs one gives scrambled channel then comes back other just quick freeze but lipsync issue. My workmate has the vu+ solo2 and says he has no issues with the cs. I have multiple internet providers issue same on both.
  • ramjet
    • 2995
    and which firmware is on your blade ?
    • diyingtime
      • 4
      Jan 4 20138a
      • diyingtime
        • 4
        I upgraded to this after issue appeared
        • jon48
          • Apr 2010
          • 147
          ive got the same issues with this software too
          • bj1
            • 445
            I run the same firmware with no issues,
            But I have found that running cccam& n-cam at the same time causes simular issues,
            So I disconnect the lines I am not using and it runs as sweet as a nut
            • vorlon2257
              • Sep 2011
              • 356
              I'm getting the same as well with the same firmware and I have only the 1 provider on it so there is no conflicts.
              • diyingtime
                • 4
                I still have issue with only one cs turned on
                • happy_highlander
                  • Aug 2010
                  • 3535
                  I didn't get involved in this thread because it always going to blatantly breaking dk rules. All I will say is multiple items on the c protocol can cause an issue but multiple items on the n protocol usually work fine
