Hi
Here is how to customize oscam webinfo with picons in status and user tab instead of text
i have included both files required in zip folder picons if you don,t want any of the files just delete them ..header.tpl..gives you dark background very stylish...CLIENTSTATUSBIT.tpl..this gives you picons in status tab if you remove this you will only get picons in user tab ok only thin required is you need to upload this to you oscam files directory...oscam.conf..etc...my directory is usr/local/etc/picons.. you just need to use correct directory if you are using dreambox i guess your directory is var/etc/picons only one thig to do you need to enable this in oscam.conf..webinfo part..httptpl = your directory..httpshowpicons = 1
[webif]
httpport =
httpuser =
httppwd =
httptpl = /usr/local/etc/picons
httprefresh = 10
httphideidleclients = 1
httpshowpicons = 1
httpallowed = 127.0.0.1,192.168.0.0-192.168.255.255
[webif]
httpport =
httpuser =
httppwd =
httprefresh = 10
httpshowpicons = 1
