intelsat 707
  • P&D
    • 2686
    intelsat 707
    Hi all i after the Spurs match tomoz
    i have found it on a site but it says its on Intelsat 707 fta
    is this sat still alive ??
    Regards
  • ramjet
    • 2995
    if its not, use nova sport on 39e
      Regards
      It is but you wont be picking that channel up without a massive dish and a C-band LNB as ramjet says 39? east is open with keys, dont ask me how you load them or arrange them on the F3/F5 as i have no idea but generally it will be via USB
      • Docker Doyle
        • Jul 2013
        • 23
        Hey up bud , try C+Lcampeones/HD it's on 19.2 e
        • P&D
          • 2686
          Hi ramjet
          thx for the info mate
          the box is the F3
          i have pointed the dish at 19.2e i get all the stations & they are scrambled
          downloaded the latest soft*** k*** list it says the 10/9/13 so not sure if it is the lastest
          so i have manually installed the latest key from this site gxmaxkey via the remote ....in the text file below dated 22/9/13
          Gone to N*** S**** on 19.2e but the channel does not open.....am i missing something mate
          Any help would be welcome with open arms
          Regards
          • ramjet
            • 2995
            the one I mentioned is on 39e (not 19e) and I am watching it now, but using a spider, not a slybox/openbox
            in any case I have never seen or owned a slybox/openbox (dont want one either) so cannot comment on your box, using a softcam in it, or the other channel on 19e recommended by docker who apparently is using a protek
            but I will say that all of the required channels will be scrambled, including the 19e one , and you wont be opening the 19e n**a sp**t one using any softcam keys, thats for sure (they are usually on 13e not 19e and you wont open those either)
            the txt file you posted clearly states 39e not 19e
            Hellas Sat 39?E
              As ramjet clearly stated you wont open anything on 19.2 east showing epl with keys , the one you have attached to your post is the bulsat key for 39 east. Move your dish there and it should open, I know MDT did a little experimenting with an F? and the softcam.key file and it did open the bulsat channels on 39 east
              • P&D
                • 2686
                Many thx for the quick reply ramjet.....
                Would that be the same on the other sat's the games on (not a chance of watching it with s***k***)
                Again thx for your help
                • ramjet
                  • 2995
                  nothing else obvious to me apart from 39e which it definitely works with as I have checked diema and n*** sport on 39e myself and got the footy on now
                  39e is the easiest one to pick the matches up on, especially with a s***cam key , it may actually be your only option too
                    You will only get Nova Sport to open with softcam.key on 39 east all the others listed are either not receivable in the UK or need the usual magical gift inside the box to work.
                    The other option is to wait nearer the time and see if a feed pops up on either 9 or 10 east
                    • P&D
                      • 2686
                      Many thx all
                      I better get my .Vu+ Solo2 ordered Monday then hope things get better
                      • ramjet
                        • 2995
                        you still need to locate 39e no matter which box you use, even an old cheap patched box can use a s**tcam on 39e for those bulsat channels
                        if you can pick up the fta on 39e, you should be able to use the s-cam to open bulsat on your slybox
                        • P&D
                          • 2686
                          Hi ramjet all sorted watching the end of the palace game mate....next the Spurs game 39.0E with s***c** k***
                          are you allowed to post the keys on Dk for the other members ??
                          Thx P & D for all your help
                            Yes you are but please make sure they are in notepad form and then Zipped up, please do not post them in plain view
                            Seeing as most od the F3/F5 owners on here only have a Fixed $ly dish is it really worth it.
                            • Nutsandbolts
                              • Oct 2011
                              • 1168
                              Hi. Free EPL matches on DUHOK at 57 east, freq:11568V s/r2500. Now showing Man City v Man U. Dont think there is any Saturday matches though but will check next week.
                              Regards.
