how does a blade 7000 compare to a f5 receiver
compare
Tags: None
THANKS FOR THE REPLY I HAVE THE F5 IT GOES INTO SCRAMBLE SOMETIMES FOR ABOUT 5 SECS IS THE BLADE 7000 MORE STABLEComment
When your receiver goes blank for a few seconds and displays "Scramble" before clearing again it is having a senior moment similar to someone suddenly asking you a times table question out of the blue and you have to take a moment before answering correctly.
There can be many reasons for your receiver doing this ranging from the "Senders" equipment to poor internet speeds at both ends to how many people are connected all at the same time.
However if this is happening to you on a regular basis with a trusted "sender" (by this I mean every couple of minutes) and especially with certain channels then it could be that your receivers processing power is simply not quick enough to handle those channels to give you smooth and uninterrupted viewing.Comment
