MGcamd softcam & keys
I have never heard of ecm info... What does it look like? Is there a screenshot I can see?The download link is wherever you downloaded the image from. There is usually a full button map in whatever thread you got the list from that explains what options are in what panel. If the channels clear it is connecting and you will see the ecm info and the likes by pressing the Blue button (Blue panel)Comment
No need for screen shot, short press Blue button and you will see the Blue panel which contains the installed cams use the arrows either side of the ok button on remote to scroll through the cams installed. If you have a cam installed and setup properly you will see the ecm times (the lower the better) on that screen which will confirm you are connected and scrambled channels will clear (you will need to be on a scrambled channel before you press the Blue button) as cams do not connect or show as connected when viewing ftaComment
Yes but you will need a softcam key or the unmentionable to clear scrambled channelComment
cant find the keys plugin satlover276 i am using the alliance image its not to bad i think open pli is the same go to plugins when it open press the green button when it downloads scroll down to softcams open and download the one you requireComment
I tried that but when I select the version of MGcamd I want to download it says there is an error. I think it's because i'm using the openpli 2.1 version. I think i'll just give up as I've tried to find out for myself but haven't been able to. have had to start a second job so haven't got as much time to learn as I once did i'm afraid.Last edited by satlover276; 6 October, 2013, 01:27.Comment
